Fast Fix / Drywall Back Boxes
10 Sep 2012
Birmingham
I am looking for some Fast Fix boxes so that I can wire some plug sockets up.
However, The wall I am trying to put these in is thicker than the average plasterboard wall.
basically, there is a sheet of plywood (15mm thick) then the plasterboard (20mm thick) ontop of the plywood board.
This means when I am using the deepest fast fox box my local hardware place stock, the two tabs either side can not be pushed out as they keep hitting the plywood.
I have searched online, however the only results I can see are deeper Fast Fix boxes, but the 'tightening tabs' still only tighten the same amount.
Ideally I need some fast fix boxes that would operate (allow for the tightening) for around a 30 or 40 mm thickness.
Does anyone know where I can get these? a link would be perfect.
Cheers.
Not sure they exist.
Try cutting out some ply where the lugs go with a hacksaw blade.
Yeh I've tried that - really difficult to get the saw blade in.
Ended up damaging the plaster on top.
Surely this must be a 'commonish' issue?
Any way you can fix normal boxes?
25mm is the max I can find.
If you've got that amount of depth to work with and, presumably, a void behind, can you work in a piece of batten across the hole, screw through the wall either side of the hole to fix the batten, then use a standard 25mm knockout box screwed to the batten.
PJ
Yes there is a large void behind the hole.
Good idea with the baton - I can then simply fill the holes where the screws are.
Well worth a try.
Just hope the box holes are not too close to the studs.
