Hi I have a double light switch in the kitchen controlling two lights, neither light is controlled by another switch.
The switch was very dirty and one light was flicking on and off with little pressure on its switch so I decided to replace but have now come up against a couple of problems.
Apart from the earth wires I have two pairs of cables.
The current switch is labelled across the top L1 L2 C which is repeated at the bottom. One of the pairs of cables goes to each.
At the top I have the black wire going to the C with the red hanginging loose although it appears it may have been in L2 before I unscrewed the plate from the wall.
At the bottom the wires are reversed with the black going in to L2 and the Red into C.
So the first question is am I right in assuming that the loose red should be in L2 ?
The replacement switch is completely different, its configuration is two individual blocks with L1 and L2 at the top of each and C at the bottom.
Can I use this and if so how should I wire it
Many Thanks in advance
