D
Deleted member 174758
Good idea for a domestic job!As you lay the P5 boards down us a perm black marker and draw on them the layout of any pipework and cables underneath. Be a god send in the future if you need anything doing.
Yes, where walls are perpendicular to the joists. If they are parallel to the joists but not on top of a joist or trimmer (as can happen with retro installed walls) so that the floorboards are carrying the wwight of the wall you'll possibly need to get some extra support beneath the wall if there isnt any already (e.g. 4 x 2 noggins at 400mm centres, etc), which in turn is fixed into the two adjacent joists by screws or ring nails. This makes your rip out a little awkward as you need to take the floor out a bit at a time and install the noggins as you go in those areasmarkyyyyyy said:...what would i do with the floorboard that are directly under the studwall/ door frame - would i just cut around as closely as possible and then install my new floorboard neatly to the edge of the door frame?
Probably the easiest and fastest approachIn terms of approaching pipework, it appears that some pipes actually sit in some channels that are cut into the top of the old/current joists. When installing the new joists (sistered alongside), would i do cut the 4x2 so that it stops just before pipework and a new piece of timber that starts just after...
1. I'd advise rads and skirtings off if at all possible
2. Difficult. I think I'd order the timber and chance it. Timber supply is getting easier for us since Boris's mob told the merchants to reopen. We are drawing off timber on a 2 to 3 day wait basis unless it has to be imported, so the issue may be transport. That said we tend to be takung a few thousand pounds worth of timber a time, so maybe we get better service
Good that there is no rot - one less thing to fret over
In terms of the unsupported stud wall, you'll need to add in support a bit at a time. Start by removing the skirting. Then take out the floor on both sides, but only for about 300 to 400mm length. This leaves a lot of the wall supported. Make a tight fitting noggin from your 4 x 2. Thread this in between the adjacent joists and under the wall (pulled tight up to the underside of the piece of floor which is beneath the wall). Nail or screw to the joists at either end. This provides the first support beneath the wall tied into two joists. Ideally you do need to pilot drill (and countersink) your screw holes before inserting the noggin. Pilot drill and screw or nail through the small piece of floor beneath the wall and into the noggin. This ties the wall to the noggin. Now move along another 300 to 400mm and repeat the operation until yo reach the end of the wall. This is slow, laborious, awkward and can be frustrating - but it gives your wall the support it needs.
