finish for parquet floor being restored
22 May 2012
Surrey
We have just spent lots of time sanding the old parquet flooring which was under the carpet in our 1950 house. Not sure what the wood is - it was dark but went light after sanding (sanded oak colour with a hint of cherry). We have put one coat of clear Osmo Hardwax oil on the floor and the colour has turned very dark/bright red. The bright redness is overpowering the room and I was wondering if there is a better finish we could use so that it is not as dark or bright red?
If there is a better finish, will we need to sand off the finish just put on?
Hi
You could post a picture and we will have a go at guessing the species!
Your only other options to HardWax Oil would be a coloured oil or a lacquer. Speak to the manufacturers and get some free samples.
Regardless of which other route you go, the Osmo would have to be removed.
TT
You've got a tropical species, which will show its natural colour when a natural clear finish is applied - no matter if it is HWO or varnish.
At a guess it could be Merbau blocks, check to see if there are little flecks in the wood structure.
A water based lacquer will give you slightly less colouration and closer to your before picture than a HardWax Oil, a bourneseal (if you can find a solvent based one) will give a slightly more uniform slightly darker surface.
You could also stain the floor, but to be honest, with a fantastic wood like that it would be a pity to hide it.
It all depends on whether you feel it is worth sanding off to try again.
TT
