C
Captain Nemesis
And grown ups should be trusted to make their own decisions and to be accountable for their own safety.
There is no requirement to provide any fire fighting equipment to tenants, but if you do and expect them to use the equipment, then you must ensure that they know how to use the equipment and use it safely. And you must also check the equipment at reasonable intervals and maintain a service record.Is this really the case? I wanted to use this in a garage conversion as a safety measure but this may become a burden on me if the above is true. Can you please elaborate.
Thanks for your help.
If Pontins expect you to attack the blazing settee with the blanket, then yes that may be deemed encouragement.Ive stayed in holiday lets where there have been fire blankets - are they not encouragement to remain in a building where a fire has broken out?
It's not a HMO is it.Um yes there is. If it is a HMO https://www.gov.uk/private-renting/your-landlords-safety-responsibilities
And training does not have to be given, just the provision of an extinguisher.
And if you provide an extinguisher and do not provide training then you are liable under common law if the person you expected to fight a fire is injured carrying out your expectations. So if you have not trained them, you are culpable and have no defence.
And of course you have proof of that, precedents, case law etc?And if you provide an extinguisher and do not provide training then you are liable under common law if the person you expected to fight a fire is injured carrying out your expectations. So if you have not trained them, you are culpable and have no defence.
Yes.And of course you have proof of that, precedents, case law etc?
What's the advice of the fire service for fighting fires?If you rent out a property of multiple occupancy one has to provide Fire Extinguishers etc as laid down by the Inspecting Fire Officer , I have never heard of the fact that one has to train residents how to operate a fire extinguisher , directions of use are normally on a lable on the extinguisher .
One can approach Fire Officers to give talks on Fire Safety and use of equiptment or supply leaflets on use of equiptment .
What I would do, (and do) is prepare expert reports for the Court to advise the judge when landlords have failed in their common law or statute obligations.I'm sure that Woody would also train tenants to use the oven, the vacuum, the microwave, how to open the door and walk outside too![]()
Ill decline that kind offer, thanks - Im sure I could find other ways to waste money which are actually fun.Yes.
And if you come to our office, instruct us and agree fees (we will need a deposit as you may be dodgy) we can advise on relevant law.
and thisyou must ensure that they know how to use the equipment and use it safely.
to thisAnd if you provide an extinguisher and do not provide training then you are liable under common law if the person you expected to fight a fire is injured carrying out your expectations. So if you have not trained them, you are culpable and have no defence.
in less than 24 hours. At that rate it wont be long before you are back in the real world. About the biggest thing left for you to do is to stop calling supplying the manufacturers instructions "training", as I think that youre a bit out of step with what most people would regard as "training", particularly when you use the term in conjunction with ensuring that the training has been effective.the training for use of any appliance supplied as part of the tenancy can be .. just the supply of the manufacturer's instructions.
I would suggest that there is a bit of difference (actually quite a bit) between that and actual common sense. I would suggest you stop assuming that everybody is like you.Otherwise I would suggest there is a bit of difference between throwing a bit of cloth over the chip pan, and picking up a fire extinguisher in a panic, checking the instructions to see what kind of fire you can use it on so you don't electrocute yourself or spray hot blazing fat everywhere, finding out how to arm it, then reading the instructions to see how far away to stand and where to point it, and then having a go without choking yourself to death in all the smoke.
