Fitted a Pegler lever Ball valve on the main supply -Screeching noise!
23 Nov 2006
Norfolk
When I turn it on there is a very loud screeching noise coming from the valve.
anyone had this before?
is it a faulty valve?
No idea what to do apart from replacing but not looking forward to that as it was very awkward.
JohnD
Party? What party?
15 Nov 2005
South
Cook Islands
What size pipe?
What size and type valve?
What was on there before?
23 Nov 2006
Norfolk
it's a lever Ball valve on the main supply into the house, 15mm
The old stopcock is still in place as it was completely jammed and I couldn't get to it to replace it.
JohnD
Party? What party?
15 Nov 2005
South
Cook Islands
You don't know if it's a full-bore valve?
Photos would help.
So it's on a half-inch copper pipe?
23 Nov 2006
Norfolk
sorry for not making it clear.
Yes it's 15mm copper pipe and it's definitely a full bore lever ball valve.
It's a screwfix valve . can't find the item code.
9 Sep 2005
Sussex
Did you try turning off the stopcock...sounds more like the washer or jumper's causing the noise.
Unscrew the stopcock headgear and take a look.
23 Nov 2006
Norfolk
I can't undo the old stopcock yet as I haven't got a way of shutting down the supply at the road.
Got to get one today if I can.
JohnD
Party? What party?
15 Nov 2005
South
Cook Islands
Is there a water meter? Post a pic if so.
23 Nov 2006
Norfolk
I managed to turn the water off at the meter and replaced the washer on the old Valve.
You were correct that this was the problem. As it seems to be fixed now.
It's strange that adding the new valve next to it seemed to cause the problem but Hey! it's fixed Now:)
Thanks very much for all the advice :)(y)
Mike
14 Jul 2016
Got to get what?
If you can turn the water off and get to the old stopcock to replace a washer, you can remove the old stopcock, maybe with a short length of pipe, and give superior water flow.
23 Nov 2006
Norfolk
Sorry I meant get one of those long handled keys for getting down to the water meter.
I did have a look at removing the old tap but it was not possible. The tap sticks up through the bottom of a cabinet in the corner the connection to the pipe is just below the bottom so no way I could get a spanner on it.
10 Oct 2017
I'm in the same boat with a knackered stop tap, completely inaccessible to remove, lools like lead pipe on the supply side to maje matters worse!.
Why they couldn't have fitted it another foot up the wall is anyones guess...
Did the same as you, 15mm full bore lever ball valve but would like to remove the old tap completely (envisage digging the floor out around the pipe to do it).
23 Nov 2006
Norfolk
Yeah it would be nice to get rid of the old one but not worth it I reckon, My new ball valve is sooo smooth I don't ever forsee me having to use the old crap tap again.
14 Jul 2016
The head of the old valve can be removed having a brass plug screwed on it. This gives better water flow. The washer and jumper can be removed, removing another cause of any future problem, also improving flow. Every now and then turn the ball valve on and off to ensure it does not stiffen up.
