So, this may sound like I'm over thinking the job but hear me out ...
I've got 2.5mm2 SWA to run along a section of wall that is stone with cement render.
Using SS screws and plugs I am going to fit the SWA to the render.
Should I give any consideration to the fact that by using plugs and screws I am creating a channel for moisture ingress which would lead to the render being blown over time ? Even if angling the drill hole water always finds a way in..
I was thinking some mastic or external silicone may be beneficial as you would do an outside double socket installation. Thoughts ?
