I am rewiring a house (doing the donkey work myself, and will have a qualified electrician inspect & test), and have just learnt that its probably going to be classed as an "HMO" and so need linked smoke alarms and maybe emergency lights. Please can anyone help with the following:
1. Is it correct that smoke alarms can be powered off a lighting mains? If so, can upstairs and downstairs alarms run off separate lighting circuits, and still be linked to one another?
2. Is there any requirement to use the red, fire-resistant cable seen in commercial properties' fire systems? If the answer to Q1 is "yes", then obviously the supply would be standard lighting cable, but what about the link cable? Or does one cable carry both power and link?
3. There are alarms which replace or supplement the ceiling rose, which also turn on the light when activated.
(a) How does this stand with the recommendation to position at least 12" from walls or lights?
(b) Does it turn the light on using the mains supply, or some sort of battery backup? If the former, does this count as emergency lighting, considering that it probably won't work if its an electrical fire?
4. Presumably a standardised protocol is used for the link, so I could extend without having to rely on finding the same model of alarm? Can I mix alarm-only, emergency-lighting-only and combined units on the same link circuit?
5. Does inspection/testing of a smoke alarm installation require additional qualifications to those for normal domestic wiring, and if so, is this something most electricians would be able to do, or do I need a fire systems engineer?
Looking forward to any advice you can give.[/list][/list]
