    Dismiss Notice
Fixing heavy headboard to stud wall
Discussion in 'Wood / Woodwork / Carpentry' started by xplosiv, 1 Dec 2018.
  1. xplosiv
    xplosiv
    9 Sep 2007
    93
    Thanks Received:
    Bristol
    Country:
    My wife has purchased a headboard and wants me to attach it to the wall. Who do the bed. I'm a little concerned as it's quite heavy and it's a stud wall. Do you think there's a risk the wall may not be sturdy enough to support it? I suppose stud walls can take radiators and they're obviously weighty...
    Any comments and/or tips appreciated!
  2. rsgaz
    rsgaz
    28 Jul 2014
    1,863
    Thanks Received:
    507
    Country:
    If you can screw into the studs, it will take a remarkable weight. (use a pilot drill)
    If you have to screw into the plasterboard, use 'molly' fixings and buy the 'setting tool' so it has no risk of going wrong(ruining the wall), right where you need the fixing.
    https://www.ebay.co.uk/itm/182871858549
    You need to drill a test hole first, to find out what thickness you have. 'Normal' is half inch plasterboard, but it can be double boarded, or 15mm sound board, or double sound board, etc. (plus skimmed or tape & jointed)
  3. Sponsored Links
  4. blup
    blup
    5 Nov 2007
    1,772
    Thanks Received:
    309
    Country:
  5. Yeahaa
    Yeahaa
    24 Nov 2018
    66
    Thanks Received:
    4
    Country:
    The self taping panhead type fixings I would use , a 5mm pilot hole helps when fitting the metal plug , flush brackets on the back hooked over the system screws that come with the fixing .
    Accurate marking out an transferring of measures , can adjust on back of head board if wonky .
    Imagine the headboard spans least 3-4 studs across the wall , would be possible to find the studs to get the best/strongest fix , keeping any damage , pilot holes behind the headboard so can be filled & repaired then hidden
  6. Sponsored Links
  7. foxhole
    foxhole
    14 Mar 2006
    17,985
    Thanks Received:
    2,062
    Kent
    Country:
    What type of fixing does the headboard come with ? Is it intended for wall mounting?
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
