It might not have a switch at all.And a FCU is not double pole switch?
I disagree.It's impossible to overload a correctly designed and installed circuit, even if it contains devices of a higher rating.
You can disagree all you like and many of your posts indeed do seem to do just that. It doesn't change the fact that many your ideas are wrong, in the eyes of posters here who are able to read the regs.I disagree.
But as has been proved by many thousands (maybe even millions) of safe installations the fitting of 13A sockets is perfectly satisfactory, even on 6A circuits.The regs are often wrong. That is why there are amendments correcting them. Also the regs are not statuary.
In your opinion.
I don't understand this overload fetish you keep prattling on about. The circuit is (presumably) correctly designed with 1 or 1.5mm² cable and a 6A OCPD. What is so wrong about that?Nothing has been proved. Those installations are all unsafe as the circuits could be overloaded. The fact that it has not happened to some is pure luck.
Without seeing the unit you cannot say that, it would require dismantling and void the warranty,.Yes it can if, as is so often the case, it is wrong. There is no requirement in the regs to follow manufacturers instructions.
How would people fitting this outside the UK fare where FCUs are not available or complaint?
In your opinion. Common sense clearly shows overloading a circuit by over 100% is bad practice.
There is no requirement in the regs to follow Winston's advice.
You know as well as anyone else that plunging the house into darkness due to overloading the lighting circuit could have dire consequences in certain circumstances.I don't understand this overload fetish you keep prattling on about. The circuit is (presumably) correctly designed with 1 or 1.5mm² cable and a 6A OCPD. What is so wrong about that?
