simond said:He likes heat stores.
I'd put in an unvented and if there are any issues at all about flow rates, add an accumulator, job done. If you have to have a heat store (don't understand why unless you want to fit it yourself) you can bung an accumulator on the front of that.
baggy99 said:>> don't understand why unless you want to fit it yourself
Yes, I'm DIY-ing it, so its gotta be vented.
Doctor Drivel said:The CH can have TRVs on all rads and no central thermostat to switch out the whole heating system
gas4you said:Doctor Drivel said:The CH can have TRVs on all rads and no central thermostat to switch out the whole heating system
Wheres the boiler interlock then as required by building regs other than with the Vaillant VRC400?
I've got a thermal store unfortunately. What a load of inefficient rubbish![]()
Only new build usually fits them as they don't need G3 qualifications. Cheap skate developers![]()
simond said:You can't get a room influence temp sensor with a VRC400. You have to mount VRC400 external to the boiler and invoke the internal NTC if you want room temp control.
I don't think you should give advice until you start fitting this stuff; your posts suggest you have the practical fitting and maintaining experience when you do not.
Similarly with heat stores; we can all read the manuals in the bath but I have more respect for the views of the person that dragged it out the van, installed it and maintained it for their customers.
gas4you said:How can stats on the cylinder know what temperature the rooms are, they are just water based from the store and will not prevent boiler from firing if rooms are up to temp.
The VRC 400 does this by pre-programmed heating curves that the installer selects upon commissioning.
My Thermal store is 2 years old Gledhill. with 3 pumps and a plate heat exchanger for the hot water, but it's still rubbish!
Just a combi really for the hot water side, which you can notice when several hot taps are used at once.
If I set the boiler stat to 50-60C then I don't get the required performance needed, so therefore has to been run hot and inefficiently.
I will never accept that the working principles of thermal store can co-exist alongside a condensing boiler.
It doesn't. It acts on the curves, depending on outside temp and/or flow or return or both temp. The house can still get too hot, say solar gain to the south side.
simond said:Here we go again, another load of manufacturer bumpf to read and believe implicitly.
This time we are all sent to ACV. Would this be the Belgian company I have requested literature from, twice, and received nothing?
The VRC 400 does this by pre-programmed heating curves that the installer selects upon commissioning.It doesn't. It acts on the curves, depending on outside temp and/or flow or return or both temp. The house can still get too hot, say solar gain to the south side.
The VRC400 has an inbuilt thermister so it can sample internal temperatures. It doesn't mention that in the web guff, so you wouldn't know that, Dr Driv. You have to be an installer to know.
Anyway, the OP has an oil boiler and Vaillant don't make one for the UK, the VRC is not compatible with non Vaillant gear.
esra_ptrap said:Doctor Drivels posts remind me of another keen thermal store advocate who has been long time absent ... WaterSystems!
Could they be one and the same by chance![]()
So wheres the boiler interlock then?, you missed that on google I take it!
Wrong again, the installer sets the curve, the room with solar gain will be controlled by the TRV in that room. A southerly room will not be affected by the outside temp sensor as it is never fitted on a southerly wall![]()
You will have to, as they do. I have seen them operate as low as 60C and give 55C DHW temps.
I don't have to do anything. No customer of mine will ever have the misfortune of getting a thermal store fitted. I'll leave that to the cowboys who think they know what they are talking about.
You obviously haven't a clus about Vaillant boilers or system controls other than as Simon says, looking up the info that is on their site.
I am fortunate to have info that hasn't even been publicly released from Vaillant, so bring it on(not that I would ever pass it on to someone who sounds incompetent
