The above works very well when you are able to poke the probes into a terminal of some type but I struggle with this when there are loose wires that you want to test i.e. wires removed from the socket terminals.
Incidentally, my Fluke voltage stick is very good for this but I tend not to use that now that I have this 2 Pole Tester and a number of you have suggested that there are limitations to the voltage stick.
Is there a particular technique with the 2 pole tester when used in the situation described?
Thanks in advance.
Thanks in advance.
