I've found a leak in the central heating system pipes that are buried under the concrete in our kitchen. It seems that the T-junction is where the problem is, see red circle in the photo here. The two smaller pipes that are coming off the bigger pipes were installed after the heating system was put in - they are used to supply the radiator in the sunroom.
The plumber is coming out on Friday to fix the leak, and I am assuming he will replace the joint and use solder. My question is - how strong is a solder joint and is it the strongest type of joint for copper pipes?
