Friday Fotos
14 Sep 2006
Gloucestershire
The worst manufacturer of DBs in history !:-
Spot the bodge ?:-
Tumble dryer !:-
Can I get another cable in there ?:-
Federal stablok
Reminds me of this one on a job where I was adding some circuits! Had to go a different route!
And this - I guess once they realised they had pulled it too tight, it was too late! They just didn't lit it up!
When I was an apprentice, I was on a job in a mill with my boss when he managed to cram 19 1 milli singles into a 20mm conduit. :shock:
19mm² of copper..
Or how about 9x 2.5mm and 3x1.5mm = 27mm².
Three water heater circuits and one lighting circuit all leaving a DB via a single 20mm conduit :twisted:
I don't know, never saw it loaded.
Wasn't fun swapping the board on the end of it it through, tight as **** and made worse by a load of boxing in around it. Not that it needed swapping anyway, metal clad wylex standard fuse board, fitted with 1361 cartridge carriers. doing water heaters and lighting in surface conduit in school toilets... periodic done by another firm "DB-H uses the old cartridge fuses, consider upgrading - C2" . No one listened when I objected so it got changed anyway
Still, keeps you in work. :)
Or it gives you the opportunity to complain about waste of public money.
Anybody who ever allows themselves to benefit personally via a publicly funded body spending money on something unnecessary can no longer complain about his council or the government spending money on things which they consider to be a waste.
You can choose to be part of the problem or part of the solution - both is unworkable.
