hello all. quick question/some advice on electrical matter at home. had a great response to a different problem i posted last year, so thanks to everyone on making this site what it is.
regarding fuse switch for heater in hall. 2 black, 2 red and 2 earths come into the fuse switch terminal block, and on the other side of the block is brown and blue cables.
1 brown, 1 blue and 1 Y/G go from the fuse switch to another wall panel 1 metre away for the heater.
On this panel terminal, there is the blue, brown and an earth. however there is also a very thin (like telephone cabling) coming down from the wall into a terminal block which meets the black cable of the heater.
At the mains board, there is a switch for BOTH this heater and the lounge heater (ie, they are on the same mains board switch) . Is it possible to put in a normal socket where the fused switch is, or even where the other wall panel is.
socket would be used for plugging in hoover etc
many thanks in advance
dg
fuse switch
other wall panel
[/img]
dg
fuse switch
other wall panel
[/img]
