Garage roof repair
19 Nov 2023
hello!
Could someone advise me on the best way to repair my garage roof.
Flat roof. - felt with stones.
The flashing into the gutter has worn, which is now allowing a small amount of water into the ply underneath.
Looking for the best way to seal.
Hi there! it looks like the flashing and roof edge have significant wear, which could lead to more water damage if not addressed properly. While a temporary fix with bitumen tape or liquid sealant might help for now, the condition suggests it might be time to consider a professional repair or even replacing the roof if there are other areas with similar wear.
Roof looks like it's had its day.
Needs stripped off and recovered.
You could use something like EPDM to recover it.
Hi there!
It sounds like you're dealing with a leak around the flashing on your flat garage roof.
For some helpful info on flat roof repairs, check out this article: Flat Roofing: A Modern Solution for High Wycombe Homes from Aztec Roofing.
While it might not be specific to your exact situation, it provides some good general information.
For the best advice, it's always a good idea to have a professional roofer take a look. They can assess the damage and recommend the best repair solution for you.
Hope this helps!
Acrypol, cromapol would be your best bet for a short term fix..got to be clean and dry...your local builders or roofing merchants stock it.
