Gas supply to new hob
Why would an author want to read his own book :LOL:
Perhaps we would have been better staying as apes, I mean they don't have religion, Dirty Government that want to control our lives, Taxmen that want every penny we get, And they can hug as many trees as they like and still be normal.
Fight to the death, the winners in charge, and if the itch doesn't shut up you can eat her. :LOL:
You can still hug trees if you want DIA, you could be discreet about, it can be your little secret no one would think your weird if they didn't know!
Always fancied life as a bonobo myself, better sex lives than we do!
Also where is this manometer going to be connected to on apipe not attached at either end.
You REALLY don't know the answer?
FiremanT
Von danoken an idiot got that wrong liar maybe(ON OCCASIONS) but not an idiot he has sold 63 million books and made several million doesnt sound like an idiot to me.[/quote]
He may (or may not) have made millions and sold a lot of books, but that just proves that idiocy can be profitable, and that some other idiots will believe anything.
But my comment really reffered to motormouthmikefrom london's assertion:
latest evidence found from ancient civilisations indicate man was planted on earth, from other planets
Latest Evidence! ? Von D wrote his first lot of nonsense in the 70's.
How do you pressure test a gas pipe which is open at both ends?
Oh damn! That is a seriously tricky problem, what a set back! will we ever achieve landing on Moon? we have stumbled across a big major issue,
But wait, let us not call NASA as yet, what if we just plug the pipe at one end and then you place another plug at the other with a small nipple attached to that plug, so that we can now pump some air pressure to about 20-25mbars, and use a pump that has a non return valve and tee fitted for your manometer, and then wait for 1 minute for air to stabilise, and then wait a further 2 minutes and then observe our manometer to make sure no further pressure drops, wow problem solved boys!
Now, how would you go about making the plug?
Oh yes I didn't realise it is beyond an average Gas Safe Operative's abilities, God knows how they get ACS and other qualifications.
Firemant .
ok tell me where this manometer is going to be connected on a double open ended pipe and if connected at what pressure would you air test it at ??.
No its not a case of may or may not he has sold 63 million books and and as a result of his theories has made millions.Enough to even open a multi million pound theme park several years ago.
Whether he is an idiot because you dont believe his theories is a personall choice.
People used to believe the earth was flat and there was no such thing as gravity those people thought that anyone who didnt believe them where idiots to
Even Motormouth from London knows the answer, which was posted hours before your last. Have you never tested a carcass?
Not read mikes posts i am asking you the question where do you connect a gauge to a pipe that is not connected at either end .
Tested many carcasses but can you tell me what pressure you would test just a carcass at with air with no meter attached ?
Mikes method involves closing the ends off so it is no longer open ended is it??
OMG - Not been on this site for a couple of years - This 1 thread has had me in stitches; I've not seen 1 bit of advice justified and read a total load of garbage from both RGIs and a certain someone from London called Mike - All of which has been highly entertaining I must say.
I'm one of those evil RGIs that doesn't give away trade secrets; but I must just add the simple point...
This is 2012 - We've learn't a lot about Gas in the past 30 years. Forget what you "think" you know; these days you need to know...
Any DIYer can undertake gas work so long as they are "competant" to do so; they do not need to take a test, be accredited or registered with the HSE under the Gas Safe scheme. However; they must be competant; the information requested is quite plain to see in any of the gas engineer publications such as Tolley's and Vipers... To be "competant"; we'd expect that one of these manuals was to hand as these are the "regs condensed" as the job involves the following stages:
a) Assess the desired appliances, is it a 2 ring, 4 ring, 5 ring burner; has it got a wok burner in the middle and what is it's NET gas input value (Irregardless of whether or not the appliance has been purchased, the home owner will need to know so that the pipework can be sized accordingly).
b) What is the desired route and where will the connection be into the original carcass? Is this going to simply tee into an existing supply and will that existing supply need to be upgraded to safely supply the new appliance?
c) What material is being layed on the floor; we're suggesting a screed as underfloor is going in; as such, we need to wrap and protect the pipework; if it's a complex run, we go under the underfloor, add volume to counteract the effect of elbows, bends and fittings.
d) The homeowner stated that it is "roughly straight", well copper is straight - How are the bends being formuated; or is a flexible gas pipe being utilised like TRAK... In which case; this will effect how the pipework is protected from the corrosive effects of the screed.
e) Pressure testing must be carried out - Any gas engineer that leaves a gas leak has NOT done their job properly - In a standard domestic situation it takes 4 minutes - No more; no less; no excuses.
When a homeowner asking for advice can give some solid evidence that they have done their ground work and are competant; then fine, we all need to bang heads and ask for advice - But Mike; you have some balls... Congrats; you have a great and varied knowledge, but you are obviously not a specialist and should refrain from giving wrong advice - I feel sorry for the person that buys your house from you; it's obvious that they are taking on a massive project; with a 30 year old, DIY fitted boiler which may be great in your eyes, will be a costly, inefficient beast to run and replace.
Hats off to the RGIs for standing their ground; but come on, show some reasoning and not just "Get an RGI"... Explain why and justify your cash.
Check the regs; it's all in there and will vary on the type of test and size of carcass... If it comes under IGE/UP1 or IGE/UP1A then it will also vary on your test medium as the majority of carcasses need to be tested with OFN (Nitrogen).
It may also vary your test times as you no longer have let-by and depending on the medium; your stabilisation may vary.
Hey up Dan The Gas.
I explained the reasons why quite clearly, but if you didn't find it or understand.
Gas advice is forbidden by the management, and will be deleted with a warning to the poster.
You will find most forums regulate themselves and RGI's refuse to give gas advice anyway.
Get away :LOL:
