I have a technical query, which I hope someone may be able to help me with. -
Ever since I installed this boiler some 12 years ago, I have not been entirely convinced that the Landis and Gyr (now Siemens) RVP75.230 controller is doing its job properly.
Unless I manually override the three way mixer valve, and set it the mid position, the flow to the radiators is nearly always too low, usually well below 60 degrees.
What should the RVP controller in the Geminox FCX 20 E be trying to achieve, by varying the proportions of water taken from the boiler and the condenser?
I understand from the Geminox Manual, page 6, Section 5 "The Condenser", that "......with a return water temperature of 53 degrees or less, the condenser will abstract latent heat as it cools the flue gases to below the dew point.........."
As the boiler has never been fitted with a return water temperature sensor (TEMP 5), can it achieve this, and if so how?
Many thanks for any help which may be out there.
Regards
Alan K.
Regards
Alan K.
