    Dismiss Notice
Getting floor boards up
Discussion in 'Floors, Stairs and Lofts' started by markymark2406, 19 Feb 2019.
  1. markymark2406
    markymark2406
    7 Mar 2007
    449
    Thanks Received:
    2
    Cambridge
    Country:
    I have floorboards straight across my room nailed to joists underneath, I Want to cut some of them to put pipes beneath, what’s the best method please ?
  2. Sponsored Links
  3. wwwebber
    wwwebber
    5 May 2004
    435
    Thanks Received:
    24
    Country:
    Flat multi tool saw. Did this myself last week. A doddle.
  4. markymark2406
    markymark2406
    7 Mar 2007
    449
    Thanks Received:
    2
    Cambridge
    Country:
    Can you send a link to a machine I need ?
  5. wwwebber
    wwwebber
    5 May 2004
    435
    Thanks Received:
    24
    Country:
  6. Ian H
    Ian H
    14 Sep 2010
    7,026
    Thanks Received:
    853
    Rochdale
    Country:
    I used a normal circular saw, set the depth to 25mm then cut right next to the nails.
    • Like Like x 1
  7. Sponsored Links
  8. JobAndKnock
    JobAndKnock
    30 Sep 2011
    6,069
    Thanks Received:
    1,344
    Lancashire
    Country:
    That's how I'd do it - far, far faster than using a multi tool and a way to use up those cream-crackered old blades (or cheap Silverline ones you bought which turned out to be dreadful)
  9. wwwebber
    wwwebber
    5 May 2004
    435
    Thanks Received:
    24
    Country:
    How do you avoid cutting neighbouring boards ? at least with a multi tool you can get it spot on. Also try cutting a new joint up against a stud wall with a circular saw ;)
  10. Ian H
    Ian H
    14 Sep 2010
    7,026
    Thanks Received:
    853
    Rochdale
    Country:
    Neighbouring boards get a small groove cut.
    I didn’t have to go close to a wall but guess I would have cut 30mm out then added a bit to the joist maybe?
  11. JobAndKnock
    JobAndKnock
    30 Sep 2011
    6,069
    Thanks Received:
    1,344
    Lancashire
    Country:
    Mosty of the time it really doesn't matter that much, if at all, because the floor will subsequently be covered with underlay and a carpet. Where the floor is clear lacquered I'd still use the circular saw, but stop the cut short and finish with the multitool. Multitools are very slow at this task and struggle to cut a decent straight line. The blade will also be wrecked everytime you hit a nail (and old floors can have nails, broken-off ends of screws, punched-under tacks etc in them) - so stock-up well! A circular saw blade may lose the odd tooth, but it will keep going - and with appropriate guiding a perfectly straight neat cut is easily achieved
    Never really needed to do that very much. Getting within 30mm of the wall with a floorboard running at right angles to the wall is generally sufficient, even if I have to insert a support batten afterwards. Cuts along the length of a wall? Not really advisable unless you are certain that the stud wall is supported with solid strutting/noggins between the joists, and in any case I think I'd go potty trying to get a perfectly straight cut against the skirting down, say, 10 feet of wall. It would take ages
  12. cdbe
    cdbe
    22 Nov 2009
    1,329
    Thanks Received:
    240
    Oldham
    Country:
    Cut down a jigsaw blade. Make sure you have a tight grip on the saw as it may try and jump out of the cut.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
