gloworm honeywell swiftflow 80
9 Nov 2009
Northamptonshire
hi there
does anybody have access to or can email me a copy of the manual for the glowworm swiftflow 80?
i need one and also need to know if i can remove the old broken danfoss 103 timer that feeds it and direct link the electrics
i say remove it because we don't actually use it we just turn the central heating on and off from the switch behind the front panel on the boiler
can anyone help?
cheers
yes you can remove timer. the swift flow as a plug on the incoming 240v mains cable you just remove the switching wires and fit a link. I've got a manual :lol: so which part do you want (ive not got a clue how to send it to you via Email )
hi there
thanks for posting a reply
do you have a paper manual? not on computer file?.
i just need to know how to link all the wiring when i remove the timer
cheers
Why remove the timer ,
If you are just going to use on off switch then there is one on the side of timer.
because i'm tiling the wall and if i can remove the timer i can chase in a power feed to the boiler and then tile over the area
the old timer is awful looking too quite old and faded and plumb in the middle of the kitchen wall
right click on the file and select e mail then add the address :wink:
got mixed up with the compact i only have the 100 :evil: :evil:
if it is the same link 1& 2 on the boiler connecting block :wink:
