Grip wrench set
6 Jan 2009
Limerick, Munster
Ireland
I have an old set of vice wrenches, getting them to the pressure they lock tightly is getting tougher. It's there such a thing as vice pliers that is easier to lock?
Ray K
Yeah, that's them... I can't get em closed tightly without giving myself an injury. Is there something similar, I can racket closed?
Assuming " normal" mole grips- you do know how to adjust?
Are they rusty ? Lube?
please put photos up.
genuine Moles are very sturdy but there are copies of varying quality.
"Mole" is a Trade Name. https://en.wikipedia.org/wiki/Thomas_Coughtrie
"Vise-Grip" is another Trade Name.
The Vise Grip patent pre-dated Mole.
the price you quote does not inspire confidence
How do you adjust them to fit the item you want to grip and round off?
If they are a Chinese knock off they probably didn't work too well from new
A decent pair of moles isn' t too expensive
Yeah, you can see a picture of one of the bolts here.
https://goo.gl/photos/dekkRTXUtaDPWaQDA
But to be honest the set I have, have been annoying me for years.
If your trying to grip side on something that is shorter than the width of the jaws the jaws will twist.
To counteract this it helps to put a drill bit of slightly smaller diameter from the other side of the bolt so when the jaws start to twist it can only go as as far as the bit so pressure is kept on the bolt.
The best way to try and undo the broken bolts, after soaking in penetrating fluid is to clamp the threads in a vise and gently wiggle the collar to and frow, much better than grips.
litl
Maybe if you have a metal file,then file (not much) both sides of the threaded stud and use your mole type grips vertically,so the flat jaws are gripping on the flats.
If you have an adjustable spanner with flat jaws that would also work even better with the filed flat idea.
Sometimes when removing seized bolts/studs/screws first try to tighten the item then reverse the action and nearly always its comes out with ease.
out of interest is that a flue/chimney damper ?
