Grotherm 1000 mixer valve disaster
Or so it seemed!...no obvious sign of a leak and shower working great so popped out for a few hours this afternoon...returned home to water pouring through the ceiling! Seems to be running back down the pipe behind the wall.
ginger what does it take to make you realisle plumbing is not your calling in life , call someone in please
Tightened around the olive. Everything seemed fine shower worked fine no sign of any leak but must be water running down the wall slowly. Everything is fitted as stated so I'msure I am nearly there! Have a plumber coming to have a look. Ill try tightening up more on the olive if that could be the problem
nearly there.
Only a slight technical hitch.
actually ginger i take my comments back,our plumbing lecturer said you cant call yourself a plumber untill youve flooded someones kitchen.
well it might be your own kitchen but its a start along the road and you sure as hell will have learned from it.dont give up with it :)
Sooner flood my own than somebody else's. hey, you have got to try these things. It's been a learning curve. The wife wasn't best pleased mind.
ifshes anything like mine shell spot a redecorating oppertunity a mile off, better brush up on your tiling/ painting skills
