What do you mean flush from both sides?Bleeding: You just press the button on the front once and within 5 seconds it will do some fancy footwork like speeding the pump up and down for 10 minutes or so, if you press it twice it will do something similar after 5 secs, for 10 minutes, I've installed three or four (6M) for relations and didn't bother with it, when I install the pump I tighten up the inlet flange but let the outlet loose and crack open the inlet valve to get any air/water out, I then tighten up the outlet flange.
Setting the modes: the CC (fixed speed) modes I,II, III, in the middle (C1,C2, C3) will flash whichever one you've selected, C1 or C2 or C3, C1 is 2M, C2 is 3.8M and C2 is 6M, suggest C2 initially, if you turn the setting switch to the right (constant pressure or CP mode) of these CC modes, the selected head will flash for a few seconds and the display then changes to show the power in watts and also (now) the flow rate in m3/hr, each time you move it, even by a 0.1M increment it will again flash for a few seconds and then display the power/flowrate. Turning the selector switch to the left of the CC settings works the same way but you are now in proportional pressure, PP mode.
Whatever you are doing, either installing a new pump or removing/re installing a old one, ensure that you flush from both sides.
My. Magnaclean was full though! Could be the cause.
I've also rotated the screen, but don't know if i overtightened the screws
But the house symbols to the left are for number of rads etc according to the manual?
Once it completes the air releasing programme where does it push the air to?
