Gu10 led
6 Mar 2021
I have just had a extension I put up I put wire in the roof before they fitted Insulation and plaster board I have cut the hole to put the light up and there is no space if I take the Insulation above the light will it be ok
No. It will leave a cold spot above each light where condensation will form and rot your roof timbers and plasterboard.
Option A. Surface mounted lighting
Option B. Construct the ceiling/roof in such a way that it's not necessary to cut holes in the insulation to fit recessed lighting.
