Have an issue with fitting recessed lights, not snug
Rocky the hole is as big as it states in the panflet thing
Regarding the the off cut plasterboard this was the very first thing i did when i got the lights in the first place. They seemed ok at the time, even like i mention around 10 out of 16 of the lights ive fixed are nice and snug, its strange how just some of them are slightly off with two of them bein a little worse than the others. Let me follow up with some photos i took today, give me 5 mins to upload
So do it with the ones that don't work...
It might sound daft, but are your wires long enough?
I did some PL downlights similar to yours a few months back, and with the gear tray sticking a bit of a way from the fitting, by time you had got all the fitting into the hole, it was pulling tight on the wiring preventing the fitting from just sitting in quite right.
It was an easy cure in the end, but had us baffled for a few moments :lol:
RF, are you on about the main wire going into the unit or the individual cores i.e. live neutral and earth
btw here are the images
As you can see they dont look too bad from here. Even when in the premises they dont look too bad unless you concentrate on the ones im concerned about or you look at the two that give off the hologram
Nice work
But the problem is with the clip
That is what we need to see.
In a peice of board
By the way how come only one wire in each light
Rocky thanks for the compliment, everything has been self taught ;) btw everything you see apart from the mains electricity is done by myself.
Regarding the single wire, I have junction boxes in place so have a single 1.5 coming off each junction box and into the lighting unit
