Is there a low point on the clutch that now you can you turn it, it will allow the belt to sqeeze past?
The clutch come down if the centre bolts is removed but after all this time, it may prove challenging or if luck is with you it could drop with a little effort.
Removing the engine bolts and prying it over should give room as would bending the bar but the choice is yours as to which is the easiest
Edit: I think you can forget forget the bit about the clutch low point, Im talking bo!!0cks
