heated towel rail in bathroom
3 Aug 2014
Northamptonshire
I want to put a heated towel rail in my bathroom, I've read various posts saying that it's not possible to tee off the hot water pipe into the towel rail, which is fine, there are some electric rails, but are these on all the time? can you time them, obviously it would be needed in the summer, but in spring and autumn can i have it on for a few hours? Also do they need to be wired to the fuse box, or to a nearby socket?
Do you have central heating via a wet system, such as radiators on a boiler?
If so a towel rad can be connected to that and/or via an electrical element.
And you can get a programer to control the rail.
Does this heater just fix to the wall, just wiring, no plumbing?
Some electric towel rails are self-containted electric-only devices that you just fix to the wall and wire up.
The alternative is to get a "plumbed" towel radiator and to fit an electric heating element to it. You fill the radiator with water, screw the heating element into one hole and blanking caps into the others. You can get kits to do this and it seems to be quite a popular choice. I've seen the heating elements on sale in the larger DIY places so you could go and have a look.
In either case, the wall fixing and electrical wiring is much the same. To operate on a timer, one option is something like this:
http://www.tlc-direct.co.uk/Products/SMFST11.html
Whether this can legally be fitted in a bathroom, where within the bathroom, and by whom, are questions that I'll leave for others to discuss...
As already mentioned you have the panel that will just require an electrical input or you may purchase one that requires, blanking, filling and a heating element can be fitted.
also, the programmer, do they come with heater, or come separate, could you possibly give me an example please
They often require purchasing separately but I dare say there may be once available with a fitted programer.
Examples of above are:
electric towel radiators
element
water filled towel radiator
timer/programmer
The electrical connection will need to comply to part p of building regulations, electrical appliances within a bathroom require 30mA RCD protection, cables must be installed/routed in compliance to the permitted safe zones, electrical equipment and accessories must be selected as suitable for the bathroom zone they are to be installed within, an electrical appliance installed within the bathroom zones, will require to be notified to building controls, unless this is a replacement for an existing electrical heater.
