!!!!HELP HELP!!!! Isolation Valve doesn't work & Mains Stuck
I'm in the middle of trying to change a bathroom sink. I've tried to turn the water off using the isolation valve on the pipe but it doesn't turn the water off (all the other pipes seem fine).
I've tried to turn the water off at the mains in the kitchen however the stop tap (valve) thing is jammed open. I've oiled it up and try to lossen the nut of the bottom then open but no joy.
I live in a maisonette above someone else and its a fair old property. I haven't got a foggest if there is a stop valve thing outside the property......
Any help & advice would be greatly apperciated......
