- Joined
- 12 Nov 2005
- Messages
- 4
- Reaction score
- 0
- Country
The immersion heater in my house has stopped working and I called in a plumber who simply replaces the immersion element and it is still not working. (despite assurance that he has 'tested' it).
The hot water tank has a single immersion element at the bottom which is connected to a switch on the wall, which from some research shows that it is eco-7 powered.
I have carried out the following test:
(a) Press the booast button.
(b) Use circuit tester & a neon scredriver and found that the circuit has no current.
The immersion heater controller is connected into two consumer unit like boxes. The first boxes is a RCD/MCB unit and has a MCB labelled "Water Heater." The controller also has a connection into a fused box which labelled all the fuses as "storage heater".
Is it likely that under such configuration, that the water tank switch is only powered by the economy 7 circuit and hence pressing boast would not have effect anyway and that one of the fuses labelled as 'storage heater' is actually a fuse for the immersion element & has gone ?
Thank you veru much in advance for your help...
