Hello,
I have recently moved into a newly built flat. Since moving in, there have been numerous issues and I have no confidence that the building work was carried out safely/correctly.
My current concern is that of the gas connection to my boiler. I am unsure if the way it has been connected is safe. I have posted some pictures and would appreciate any input as to wether or not this looks safe. If nessesary I will have someone inspect the installation if anyone sees a cause for concern.
Firstly, the gas enters my home here:
http://img268.imageshack.us/img268/6461/img0030idc.jpg
Is this yellow flex allowed? I have read that flex is not allowed to pass through walls.
Then my boiler:
http://img194.imageshack.us/img194/3056/img0031i.jpg
http://img34.imageshack.us/img34/2296/img0032kgc.jpg
http://img268.imageshack.us/img268/560/img0034y.jpg
My concern here is the white pipe. Is this the gas input? It looks very badly joint at the top and bottom. (At the top is is met by flex which doesnt look properly sealed and the bottom is filled with some sort of filler)
Is there an immediate cause for conern judging from the images? Would it be advisable to have someone inspect this set-up based on these images?
Thank you in advace,
John
Then my boiler:
John
