Post picture of the label on the camera …
The labe says itsPost picture of the label on the camera …
What is a PALOk from what I can see the output is standard PAL composite output
There is a reset button on the back that i have pressed, to be honest this is an ip camera it looks a good spec …but it may need resetting …
I dont know where to buy a proper connector for it fromwhybthe video out isn’t working is ? Bad connections at your end …software issues in the camera or it’s faulty anybody’s guess ,
Do you mean the eithernet cable?try to connect via a pc …
That makes no sense …how is a more modern ip camera more likely to work on a modern TvThrow it away (recycle it) and get yourself a more modern IP camera.
Then your much more likely to be able to see it on your tv.
Google can then tell you how to set it up.
IP cameras can be seen over the network yes?That makes no sense …how is a more modern ip camera more likely to work on a modern Tv
it looks nothing like that at allIP cameras can be seen over the network yes?
I have not watched this but a simple google search brings it up:
Smart TV's can have apps installed.
But where do you get one form?then you probably need a BNC to phono cable, and that connects to the yellow phono socket on your TV.
You can order them online, but check this is actually what you need, as I only took a very quick look at your issue.But where do you get one form?
I take it you didn’t bother to read all the thread ?You can order them online, but check this is actually what you need, as I only took a very quick look at your issue.
It’s allready been said and it looks like the poster has allready bodged up a lead to connect it !
So are you saying I need a BNC from the camera to a yellow phono to the TV, instead of a coaxil to the TV instead?
