Help with Accenta Mini
4 Feb 2011
Liverpool
Hi
Can anyone help with this please.
The alarm has started going off of it's own accord.When I reset, the tamper light comes on. Gone off five times since 10 o'clock this morning
ok, then one of the sensors has a tamper fault, what kinds of sensor do you have in your house? door contact, movement sensor, shock sensor?
ok, then it is a loop tamper.
if you want to, DISCONNECT MAINS SUPPLY,
power light on keypad should turn off,
then open main panel, tamper should go off. silence at keypad.
then find the loop tamper terminals on the main board marked TAMP and disconnect all wires from the terminals.
then put each device wire into the terminals again.
stop when the tamper shows up again. the device which caused the tamper after connection is the problem device.
I've put the power back on & the numbers on the keypad have lit up but day & power aren't lit up
No it didn't. I've connected the two wires back into the main console numbers 19 & 20. Nothing happening but the light outside is still flashing.
ok, it looks like it may be time for a new panel, i am sure someone else could help here since the fault may be deeper into the panel than expected.
Thanks very much for all your help.Before you go, is there any way I can stop the light outside from flashing
