If it is that solid then I can see a way of calculating that by adding together ("integrating") an infinite number of segments whose areas are easily determined in general form, and subtracting thrice the result from what would have been an enveloping cone.the wood removed at the corner will be a triangular pyramid with a circular base. Don't know what that's called or how its volume is calculated.
You were going well until you said thatthe rest is geometry.
How do you integrate squares, or trapezoids if you want to be a little more accurate, to build up a square based pyramid? Can;t see what function you'd be integratingWell the volume of any 'regular' pyramid is 1/3 x area of base x height. This comes from integrating (therefore adding) the slices of the known area of the base to the point (which has zero area) over the height.
And yet the faces are flatThe base must be circular (think core bit).
It's not possible to estimate as you are putting a round peg into a square hole so to speak, and since Pi can't be calculated without incurring infinity it can't be done on paper.
Only way to do it is to weigh it before drilling and after, but you'd never get the same answer twice, thus chaos theory is invoked.
How do you integrate squares, or trapezoids if you want to be a little more accurate, to build up a square based pyramid? Can;t see what function you'd be integratingWell the volume of any 'regular' pyramid is 1/3 x area of base x height. This comes from integrating (therefore adding) the slices of the known area of the base to the point (which has zero area) over the height.![]()
