- Joined
- 27 Sep 2017
- Messages
- 7
- Reaction score
- 0
- Country
I recently moved into a house and the boiler installed is a Vaillant EcoTEC plus 618. There is hot water tank for the shower downstairs and that has a water thermostat on it too.
Boiler: Vaillant EcoTEC plus 618
Hive Dual Channel
I have attached the current wiring of the Hive, which does not work till this day. Currently hot water only comes on if the heating is on. This should not be the case.
I have attached a picture of all the wiring, maybe someone can work it out.
The Hive Thermostat is connected wirelessly and the old Thermostat wiring have been disconnected.
I just need the Hive to control the hot water and heating separately.
Also if you notice there is the Valves that control the water flow for the hot water I believe.
The Hive Receiver, this attached to dual channel Water and Heating
The boiler wiring
The black wires control the valves
Junction box in the loft, where the wires from the boiler, controller, valve, Thermostat for tank all meet.
the hive 2 channel control receiver unit
Thank you
Sal
Hive Dual Channel
The boiler wiring
Thank you
Sal
