Well, no matter how long it has remained in service in that condition, I would certainly not want it in-service in my house!... Yes, that CU is definitely in service.
I'm not overly practically worried, the incident that caused the roasting was a long time ago during the build of the house before the final circuits were installed. I note that there is a replacement CU kit in another cupboard that must have been purchased to replace but never installed.
You don't really need to ask us that question, do you?! If that CU is in service, it's a major hazard which, as I said, would be immediately apparent to anyone (no matter how little understanding of electrical things they had) who looked at it (which he presumably didn't!) - so, yes, it obviously should have been 'mentioned' (in a big way) in the report!I was mainly interested to know others' opinions about whether this should have been in the home report. I was never convinced that the statutory home report would be a Good Thing but certainly this chap seems to have turned the concept into a £750 joke.
So there's a history of negligent electricians as well as inspectors.the incident that caused the roasting was a long time ago during the build of the house before the final circuits were installed. I note that there is a replacement CU kit in another cupboard that must have been purchased to replace but never installed.
Fair enough.I'm not overly practically worried
Rather difficult to imagine what circumstances could have caused such an 'incident', but regardless, anyone who subsequently installed or connected anything to that mess is a fool, no one with any sense would have even considered using a CU in that state.I'm not overly practically worried, the incident that caused the roasting was a long time ago during the build of the house before the final circuits were installed.
If you or anyone paid £750 for that, you need a refund.I was mainly interested to know others' opinions about whether this should have been in the home report. I was never convinced that the statutory home report would be a Good Thing but certainly this chap seems to have turned the concept into a £750 joke.
Quite so. As I said ...That CU is a total loss, and requires immediate replacement. On an EICR, it would be a C1. .... no one with any sense would have even considered using a CU in that state. ... If you or anyone paid £750 for that, you need a refund. ... A totally random person picked from the street could have made a better job of it and only taken half an hour.
One has to assume that he didn't even see that consumer unit (so what else didn't he look at?) - since even a 5-year-old who saw that would probably realise that something was wrong!
I can't tell you what the scope of that "home report" is. When someone commisions a survey or inspection, they usually specify what they want the 'scope' to be - but this one was presumably some sort of 'off-the-shelf product'.I do intend to take this up with the vendors of the house, and quite possibly with the surveyor himself. But -
what are the limits of this "home report"? for instance, is the surveyor required to open the lid of the fusebox?
Yes, I commented earlier on that 'covering of himself'. However, I still think he probably has a problem. If he wanted to totally wash his hands of the electrical installation (leaving the electrical bits blank, or with "N/A" or whatever) and merely recommend a specialist inspection, that would be fine. However, he has given a 'Category 1' ('no immediate action required') to the electrics - which is dangerously wrong. That, I would say, is the main thing that seems 'wrong' to me.I have run this (smoked fusebox issue) by a distant in-law who is a MRICS surveyor and has done these reports, she advises that he has in fact done all that is required, by advising a specialist report on the electrics ....
Absolutely ideal then for naming and shaming, and without too much effort making it very hard for him to ever get any work again? A bit of care needed though, I guess, given the truly disgusting, oppressive, uncivilised libel "laws" we have in this country. (In quotes because it's impossible to accord them any of the respect associated with the concept of the rule of law.)He's a one-man band, and the area is very tight-knit community.
Even without opening it he would have seen a blackened, melted hole in the door, and smoke residue above that.Whether he was required to [open the lid of the lid of the fusebox] or not, I sincerely hope that he didn't open the CU and see what we have seen - if he had, his report really ought to get him into jail!
The MCB that was next to the main switch was the first failure from severe overload and /or loose terminal. The heat from that fault melted the cover and therefor was hot enough to have damaged the adjacent main switch. The MCB that had been next was scorched and has been replaced but then fitted as the far end of the row of MCBs
With that much damage at the front of the CU there is no doubt there will be carbon and maybe copper deposits spread around the back of the CU. If the main switch was an RCU it is likely these deposits could cause enough earth leakage to trip it.
IT NEEDS TO BE REPLACED
True.Even without opening it he would have seen a blackened, melted hole in the door, and smoke residue above that.Whether he was required to [open the lid of the lid of the fusebox] or not, I sincerely hope that he didn't open the CU and see what we have seen - if he had, his report really ought to get him into jail!
That report refers to gas supply stating 'bottled Butane gas plumbed into cooker hob. Gas bottles stored against wall'
So where are the cylinders supplying the hob? If outside don't expect hob to work in cold weather. Or has he got the gas type wrong?
Propane then - which is far better than butane.It's orange bottles, standing outside behind the house.
