Honda Izy HRG415C2 SDE starts then stops
Just that it is a vacuum pump in the HP pump and I wondered if the leak off was connected to it.
Peter
When it starts to misbehave, presumably squeezing the primer bulb sorts it - can you see bubbles in the clear pipe on the right hand side of the filter?
I can't see any issues with removing the leak off pipes, and seeing the discharge is equal from each one.
John :)
Yes it does but no bubbles, the air must be getting in at the pump end. No in tank pump only vacuum from the HP pump.
Peter
