Hi guys
Over the weeks I have been installed a Accenta system in my house. Its a new build and the builder ran all the wires for the cables (he plastered over 2 of them so had to use a wire tracer to find them)
The unit went in okay and I have doen all the tests in and all the doors and triggers are working okay.
The problem is, when I set the alarm the door unit works fine but the PIR units show as a fault and do not set off the alarm. I am sure I set the wires correctly.
When I unset the alarm it shows the zones with the PIR that was triggered as F.
Now... the only thing I didn't do was set the tamper on the PIR's, I left the short on the control unit which I thought would work okay... I have also tried shorting the tamper circuit on the PIR's but that didn't work. Does the tamper circuit need to be properly wired with the PIR's to work? Its messy wiring to conenct all the tampers together.
