Honeywell Galaxy 16+
I'm have one that says bell 12v, and if I connect it to that then touch the other wire on the - the sounder goes off, even when the alarm is not set
I also have a letter T on the board, which I assume has something to do with the bell, because if I don't put the letter T to the - I get a bell tamper
So if I just use these too the T as my live and the - as the negative then I get nothing, even when the alarm goes off the sounder is silent
You need to connect the "GND" to the switched bells output. It is labelled with a symbol of a bell and has 1003 just below it...
I get a bell tamper, so can not exit out of engineer mode
The only way I don't get a bell tamper is if I attach the T to the -
Yes but you also need to make the other connections as I mentioned above in addition to the negative to Tamper link
sorry to sound thick, but i am not understanding what your saying then
if i connect the "GND" (blue wire) to the switched bells output 1003 where does my live go, i assume its the 12v Bell?
I then connect the T to the - ?
is that right?
If the internal sounder has a tamper you can add the switch to the circuit. If not, then just place a wire link between 0V and T.
pleased to say its working :)
thanks for the help
now for the selfmon!
just need to add my account to the panel, as i already did the rest
gulp
thanks Galaxy Guy, thats my kind of help!
will give that a go for sure, i just need to workout this selfmon thing!
i can control the alarm via the phone, and also away from home as i set up a port forward!
i added a few quid to my account, and just need to workout where i put all the info to get it all working :)
Just follow the panel settings from the selfmon site exactly and it should all work. GalaxyGuy's your man though :wink:
In your account, click on the panel settings and go to the G2 section. Ensure you use port 10005, as that is the one for the LCE module.
Thanks for helping out. Your advice has been spot-on. It's been a 'birthday' long weekend for me, so haven't been able to keep up with the site.
Your welcome. Merry birthday .
I don't usually feel all that qualified to asister but I'm becoming very acquainted with galaxy panels now
well my panel is working thanks to you both, and others so you must have done something right lol
Right i did all the selfmon stuff and got an email off the alarm, so thats good
how do i test the text, and calling? do i just set the thing off?
i only want it to alert me if i get an intruder or tamper, i am not interested in setting and unsetting ect ect
