Hi Fellas
14 years later...but I'll give it a shot as I'm on my night shift
My gas fitter has diagnosed my Rayburn 380g Honeywell V4600T 1011 gas valve as faulty .
As gas safe guys are busy, I am tasked with getting a replacement gas valve for him to fit.
After interneting this to death I have found the following.
A new replacement V4600T for £362
The 14 year old long shot comment (above) that the V4600C will replace the V4600T ...The V4600C costs anywhere from £100 to £150 ish
Is this the case ?
Is there anyone I can ask ?
I know it's an old boiler but I'm not going to get it replaced this side of Christmas and it getting cold....
Yours in Hope Chris
Thanks Ian
As far as I can see from the information online.
The V4600C is Softlite with Regulator
The V4600T is Slow opening with throttle valve.
I think I'll check about a bit more by speaking to someone at Rayburn and get some solid information first hand from them (as you suggested in the other thread)...but I'll probably go for the £365 direct replacement anyway ....unless I get a that solid information from Rayburn.
