Honeywell motorised valve / HW Thermostat wiring
2 Nov 2008
Essex
Can anyone advise please.
A plumber has fitted a replacement V4073A motorised valve to a friends, all Honeywell CH system. Problem is, hot water is bleeding into the heating side of the system and the valve does not appear to be controlling this correctly. Independently, the programmer, wall thermostat and tank thermostat all appear to be functioning as they should, however i am wondering if the tank thermostat wiring is correct, and if this is the problem.
In the instructions for the valve it states, relating to the tank thermostat : " on double output programmers" "omit the brown wire and revese C & 1."
At present C = Brown, 2 = Blue, 1 = Yellow, E = No wire
So if I omit brown I no longer have a C. Do i move the yellow to C as suggested and does Blue now at 2 move to 1, or does the blue stay where it is, at 2 ?
what makes you think this is happening
As far as I am aware because the original valve was faulty. Not sure if the new valve which has 5 wires, no Brown, replaced an old style valve with 6 wires. which is why i am wondering if the wiring for the cylinder stat needs to be changed as implied in the instructions.
The valve appears to have no power to it, the lever on the side moves freely up and down with no resistance. I have removed the valve head, and the spindle to which it attaches can be moved with finger pressure, so i guess the ball is free.
Don't think its reverse circulation, not sure though.
Can't be certain as to the make of the former valve head, I assume Honeywell as the whole system is Honeywell.
Again, can't be certain of the fault on the old valve. sorry.
