- Joined
- 9 Mar 2007
- Messages
- 6
- Reaction score
- 0
- Country
ok I am planning to have a renewable system with solar panels and battery and inverter, and a generator as backup to that also. All the kit to be installed in the garage and run a cable into the house. The plan is for this cable to feed into a changeover switch which then supplies a new consumer unit. Then I swap some of the existing circuits from the main CU to the renewable CU. With me so far?
Question is: what is the established, de facto way to earth such a system. Having read through posts on this I am not totally clear. A 230V inverter/generator puts out 115volts on both live and neutral. So
Q1) is it ok to bring a 2core L+N SWA cable to the house, and then run the earth from the cable gland to the new CU and on to an earth rod. I know this isolates the new CU totally from the grid, but does it give RCD protection?
Q2) I don't understand some comments on other posts such as: "if the generator has neutral and earth isolated then join them at the generator plug" Surely that sends 115v continuous to earth, which cannot be right?
Only a beginner on this, so can I have plan english answers please?
