30 month old. Fault - worked fine sometimes, all lights flashing sometimes, sometimes failing in mid program. Several sites suggested it was the main PCB at fault.
I decided to take a good look at the PCB first, rather than chase a replacement. Round the back of the machine, you remove a small oval plastic cover, remove the self tapper below it which retains the PCB's casing, then take off the much larger belt/motor access panel too wiggle out the PCB in its white case. Take careful note of what connections go where as the unit is unplugged.
C17, a 680uF 10v electrolytic cap had some mild signs of swelling on top, so I replaced it with new 1000uf 10v from my stock. Which has completely fixed the problem.
Obviously I'm not sure whether this was a one off faulty capacitor on our machine, or whether it might be more widespread. If a design error it might be better to replace the 10v electrolytic with a 16v version.
