Hi Rocks,
Probably get bored of the same questions but, my machine runs a full cycle ok and empties ok, and the door unlocks but at the end the wash enhance and on/off button still flashes, I have already renewed the pcb from emw, as all the lights use to flash and it wouldn't do anything also I have removed the pipe from the bottom of the pressure switch and blow down both the pipe and the switch, the switch seems to click ok, and the pipe doesn't seem blocked, should I be hearing water when I blow down the pipe?? Am I to assume if the mc doesn't empty the pressure switch is knackered but as it does empty it should be ok, any other suggestions??? oh, and have also checked to see if the impelor is blocked and it's not, as the machine empties I assume the pump is ok and the filter isn't blocked??
