Hi all,
My house is supplied by overhead cable to the service head, through the meter then a main rcd to an old type cu, which i intend to change for a split load type.
The only earth i can find is connected to the gas pipe, 10.0mm, which runs to an earth block and from there to the cu. i'm unsure if this is safe or if anything else is needed to bring it up to date.?
There also seems to be some bonding on the pipework around the water tank.
Any help appreciated.
