- Joined
- 21 Jan 2017
- Messages
- 95
- Reaction score
- 1
- Country
Hi guys,
8 years ago had an inexperienced friend of a friend who tiles my bathroom flooring in an attempt to fix the shower floor, the water sadly would slope outwards into the stair landing area, it is a wet room.
Problem is I would like to remove these tiles, but re-concrete the floor with a natural slope, I understand that it should be 1/4 inch for every foot from the drain to the wall. But how can I create the slope ? is there and I could do this with like a slope system i.e. them kits you can buy and lay on the floor, giving you the guide for when you lay and trowel the concrete? like this below :
or another idea I had in mind was when I remove the tiles and break some of the concrete out to where the drain is. And screw some concrete screws feet apart with each screw being higher than the other by (1/4 above) and laying a thin strip of wood on top in order for me to screed the concrete perfectly. or rather screws use small wood blocks cut to size in accordance to the 1/4, and lay the strip on there ? or wooden shims, then fill the excess concrete in the gaps once dried you know. Any ideas guys would be great, please.
below is a picture of my shower floor thank you.
