Thank you for taking the time to respond.
Basically what i am doing is sinking in the waste pipe in my bathroom preparing to tile over. I have already sunk my water pipes in but came unstuck with the waste pipes for my sink. Its was fine with the hot/cold water pipes as these only required me to chisel out 15mm-20mm out of the wall.
The waste pipe is about 30mm and i noticed after about 25mm that i chisel out of the wall i noticed i actually gone straight through the plaster and a layer of breeze block. Then after this there is a 2" gap and a fresh layer of breeze block or thermalite if this is correct?
This is all be done under my window which will be supported a lintel of some type, does this mean i will be ok to chisel out a 1-1.5m section of wall and sink my waste pipe in the 2" gap and then tile over?
It might seem long winded but i wanted to make this as clear as possible.
I dont want my wall to drop or everything disastrous. I am not very experienced at the building side of things
Thank you
Leigh
Thank you
Leigh
