    Dismiss Notice
How to cut 20mm thick steel
Discussion in 'Tools and Materials' started by madmicka, 27 Jun 2013.
  1. madmicka
    madmicka
    8 Nov 2008
    17
    Thanks Received:
    Essex
    Country:
    As the subject says I have an tank I need to scrap but its to big and heavy to move so I need to cut it up.
    its 9ft long and 34inch barrel and must be about a ton, its 20mm thick so angle grinders would take years :(.
    so I need to know what I could hire that do the job?
    thx Michael
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    22,664
    Thanks Received:
    4,422
    Northumberland
    Country:
    20mm thick? You need gas cutting gear mate - with a burner bar using oxy acetylene or oxy propane......for small cuts a Stihl saw would be ok, but not for that size.
    John :)
  4. Stivino
    Stivino
    11 Oct 2006
    3,202
    Thanks Received:
    328
    Midlothian
    Country:
    Propane and oxygen is what you need. Or your local pikies will deal with it in jig time.
  5. Mursal
    Mursal
    23 Sep 2010
    2,203
    Thanks Received:
    484
    Country:
    Ireland
    As above, a concrete saw with a disk for cutting steel, local hire shop will sort you out. Not the easiest thing in the world to hold onto for long periods.
    Plasma cutter, if you know someone in the game or might be able to hire, not sure. You will need a compressor for this setup
    You wont be able to hire the gas kit, well not over here anyway .....
  6. Norcon
    Norcon
    17 May 2008
    8,418
    Thanks Received:
    357
    Country:
    What kind of tank and where did you steal it from?
    Their usually worth more kept as tanks.
    As scrap its worth around £150 minus your costs for chopping it too pieces.
    As a pressure vessel with a plate thickness you state with full PED certification it would cost at least £3k to buy.
    A lot of customers out there for a tank like that and a lot of uses.
    Only a thief would consider cutting up a tank of that nature because they have something to hide.
  7. RF Lighting
    RF Lighting
    31 Mar 2006
    19,989
    Thanks Received:
    1,352
    Leeds
    Country:
    What was the tank used for? Any sort of cutting involving heat might not be the greatest of ideas if the tank was use for storing any sort of fuel. :eek:
  8. Norcon
    Norcon
    17 May 2008
    8,418
    Thanks Received:
    357
    Country:
    No word back from madmick then. Definately stolen property.
    And you lot aiding and abetting him.
  9. Mursal
    Mursal
    23 Sep 2010
    2,203
    Thanks Received:
    484
    Country:
    Ireland
    How do you mean?
    I know nothing about cutting up a tank ............ :oops:
  10. Sponsored Links
  11. Norcon
    Norcon
    17 May 2008
    8,418
    Thanks Received:
    357
    Country:
    Then you shouldn't be advising on how to cut them up.
    If it was a gas or fuel tank I wouldn't like to be the chap who penetrates the surface with burning equipment.
    If it is gas then its the property of the gas supplier anyway.
    My guess is madmick is a pike@y. :LOL:
  12. madmicka
    madmicka
    8 Nov 2008
    17
    Thanks Received:
    Essex
    Country:
    first off the caravan is only use 1 week of the year at havens lol.
    The tank is an oxygen chamber made in 1980 and originally from a north sea oil rig.
    We bought the tank about 8 years ago and was use 4 times a week for my daughter who has cerebral palsy, we drop the pressure down to approx 10/15 ft and she was breathing oxygen. we stop due to cost of oxygen and to her not liking it due to how warm it got.
    I am moving and the way we got the tank in was via crane over the top of the house into the back garden, the company quoted us over the phone blind and mis-judged it big time (lost over £1000) but honoured it as it was for my daughter.
    to hire them it will cost £1150 ex vat to move it :cry: and If I sell it I have the same problem so that's why is scrap
  13. Norcon
    Norcon
    17 May 2008
    8,418
    Thanks Received:
    357
    Country:
    At least now we know what this vessel has been used for. :mrgreen:
    It's just a shame you couldn't have posted that info at the beginning. Your daughters situation is bad enough but without a father a lot worse.
    Under no circumstances should you make any attempt to cut this pressure vessel into scrap.
    Just leave it alone if you cannot afford the crane to lift it out.
    We hire in telescopic cranes from time to time and the most we are charged for an entire days operation is £500.
    With the downturn in the construction industry they are much more keen for work these days.
    This pressure vessel is worth at least £2500 as it sits. You just need to advertise in the right places and let the buyer arrange the lift out.
    A potential buyer may even have their own crane.
  14. noseall
    noseall
    2 Feb 2006
    41,561
    Thanks Received:
    2,592
    Staffordshire
    Country:
    Crawling up yer own backside again eh Norcs? :rolleyes:
  15. mattylad
    mattylad
    27 Apr 2008
    7,835
    Thanks Received:
    569
    Country:
    No, I think he is answering the OP based on further information that could have been supplied in the OP.
  16. madmicka
    madmicka
    8 Nov 2008
    17
    Thanks Received:
    Essex
    Country:
    thank you for your advice, but I have only a few weeks to get it moved and the new owners def don't want it left.
    As you say its is worth more as a tank than scrap but I've offered it for FREE to 2 diving comps that make/repair and sell them if they can collect but they ain't interested.
    so scrap it is im afraid, unless u want it? lol
  17. Burnerman
    Burnerman
    7 Feb 2008
    22,664
    Thanks Received:
    4,422
    Northumberland
    Country:
    Is there no way you can get a grant or other financial assistance with this Mick?
    You certainly deserve it.
    John :)
Loading...
Share This Page
