How to spray expanding foam into tight gaps?
r_c
19 Jun 2016
Hello all
I hope you can help me. I do a little DIY, but I have a lot to learn. The current cold snap has made me realise how leaky my house is and I am on a mission to try and patch it up. I have noticed in our kitchen that there is lots of cold air coming in between gaps between the floor and the skirting boards. The floor is concrete with LVT (sadly we did not realise how uneven it was when it was done) and the walls are mainly dot and dab.
The gap between floor and floor board tapers down from about 5mm to 0. If I taped up the area, to avoid spoiling it, is there a way to get expanding foam into that small gap?
I have found items in America that look promising, but I cannot find similar in the UK
Is expanding foam suitable here? And is there something I can use to help direct the foam into that tight spot?
I do have a foam gun, if that helps.
Thank you!
Foam is not suitable here if you want to do the job with the skirting and flooring still intact.
You can get neat products like DraughtEx or other clones that are a foam rod you shove in and it expands.
You might then want to investigate where the air is comming from in the first place - if the joist ends are exposed into the cavity without filling gaps around or the dot and dab does not have a continuous perimeter of dabs perhaps.
  • Thanks
Reactions: r_c
Agreed - caulk the gaps. Expanding foam works slower and slower the nearer to freezing point you get and below 2 or 3 degrees C it just stops expanding - and after a cold night, as we've recently had, the materials you are trying to seal can be very cold
  • Thanks
Reactions: r_c
would silicon be better - try to squeeze under the gap, wipe off along the skirting, so nothing showing as such.
No, caulking would be better as it can then be painted to match the skirting boards.
  • Thanks
Reactions: r_c
Does caulk allow for expansion of wood floors though? Thought I read once that silicon better with some types of wood floor under skirtings. But caulk probably easier and cleaner!
  • Thanks
Reactions: r_c
That looks a bit like the Compraband we use for sealing floor edges against rough brick walls, etc. It's good, but the stuff we use runs about £20 a roll, which is maybe a bit pricey for a small job
Thank you all for your suggestions. I'm sorry I was not clearer, but the flooring is not floorboard - it is just vinyl tiles on a concrete subfloor (with underfloor heating).
In other parts of the house where there are floorboards, and the same problem, I have used caulk and that expanding foam (not at the same time). The foam works well, although is hard to squeeze in. But you need a certain size gap.
@Swwils Unfortunately the house is all done, and I cannot pull off bits. But you are probably right about there not being a "continuous perimeter of dabs". I would have never known to check for this in the first place :-(
Just done this process on a couple of my rooms, I used a good quality clear sealant and standard gun... You can get a Good finish and it’s a lot less messy than foam.
  • Thanks
Reactions: r_c
I think it is worth mentioning that there is such a product as paintable silicon caulk
