Hello all
I hope you can help me. I do a little DIY, but I have a lot to learn. The current cold snap has made me realise how leaky my house is and I am on a mission to try and patch it up. I have noticed in our kitchen that there is lots of cold air coming in between gaps between the floor and the skirting boards. The floor is concrete with LVT (sadly we did not realise how uneven it was when it was done) and the walls are mainly dot and dab.
The gap between floor and floor board tapers down from about 5mm to 0. If I taped up the area, to avoid spoiling it, is there a way to get expanding foam into that small gap?
I have found items in America that look promising, but I cannot find similar in the UK
I do have a foam gun, if that helps.
Thank you!
- 3.5" NEEDLE TIP CONE FOR SHARP CAN FOAM
- Needles for Todol guns <- these look more like syringes!
Thank you!
