How to spread BAL WP1 tanking?
26 Feb 2005
Gwynedd
What is the right way to spread the tanking gunk onto the walls? Will it brush on or use a plastering trowel?
By trowel is best, if you brush you should brush in both directions, make sure you cannot see the background after, remember that `gunk` is a rubber membrane, any gaps and it can leak, you can also use a roller!
Good luck
Good luck
i use a pasting brush and have NEVER had a problem.
